Saltar al contenido principal
DOPO 10.1 Tablet Dual .3 mega pixel Camera Replacement
Qué necesitas
  1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: paso 1, imagen 1 de 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: paso 1, imagen 2 de 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: paso 1, imagen 3 de 3
    • You will have to remove the back of the tablet. To do this, take the plastic opening tool, and insert into the side of the tablet and twist. This will pop off the side.
    • Slowly pull up on the cover until it is completely off.
  2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: paso 2, imagen 1 de 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: paso 2, imagen 2 de 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: paso 2, imagen 3 de 3
    • You may notice that the battery is in the way. No worries, it is easy to move. All you will need to do is to gently lift up on the battery with a small constant pressure to release it from the adhesive.
    • Carefully put it off to the side.
    • Once the battery is removed you will see a gray wire. Lightly lift up, and move it out of way.
  3. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: paso 3, imagen 1 de 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: paso 3, imagen 2 de 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: paso 3, imagen 3 de 3
    • Locate where the camera is plugged into the motherboard. It should be on the left side of the motherboard just above the center.
    • Once located lift the black lever on the right side of the connector. This will release the camera.
    • Once the lever is lifted, pull out the camera by gently tugging the cameras connector tape.
  4. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: paso 4, imagen 1 de 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: paso 4, imagen 2 de 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: paso 4, imagen 3 de 3
    • Remove yellow tape that is securing the camera to the back cover.
    • Now take tweezers, and gently grab one of the cameras. Once grabbed, begin to twist to remove from device. Do this for both cameras.
Conclusión
For information you can go to http://www.doublepowertech.com/download/...
Kaitlyn Hayes
Miembro Desde 01/21/15
414 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 5-2, Brown Winter 2015 Miembro de USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 299
