Saltar al contenido principal
DOPO 10.1 Tablet Buttons Replacement
Qué necesitas
  1. DOPO 10.1 Tablet Buttons Replacement, Removing Back of tablet: paso 1, imagen 1 de 3 DOPO 10.1 Tablet Buttons Replacement, Removing Back of tablet: paso 1, imagen 2 de 3 DOPO 10.1 Tablet Buttons Replacement, Removing Back of tablet: paso 1, imagen 3 de 3
    • You will have to remove the back of the tablet. To do this take the plastic opening tool, and insert it into the side of the tablet and twist.This will pop off the side.
    • Slowly pull up on the cover until it is completely off.
  2. DOPO 10.1 Tablet Buttons Replacement, Remove Old Buttons: paso 2, imagen 1 de 2 DOPO 10.1 Tablet Buttons Replacement, Remove Old Buttons: paso 2, imagen 2 de 2
    • Buttons will be located on the white back case. Apply small amount of pressure, and they should pop out.
Conclusión
Kaitlyn Hayes
Miembro Desde 01/21/15
414 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 5-2, Brown Winter 2015 Miembro de USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 681
