Saltar al contenido principal
DOPO 10.1 Tablet Battery Replacement
Qué necesitas
  1. DOPO 10.1 Tablet Battery Replacement, Remove Back: paso 1, imagen 1 de 3 DOPO 10.1 Tablet Battery Replacement, Remove Back: paso 1, imagen 2 de 3 DOPO 10.1 Tablet Battery Replacement, Remove Back: paso 1, imagen 3 de 3
    • Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers
  2. DOPO 10.1 Tablet Battery Replacement, Locate Battery: paso 2, imagen 1 de 1
    • Locate battery, and examine wires connected to battery.
  3. DOPO 10.1 Tablet Battery Replacement, Remove Battery: paso 3, imagen 1 de 3 DOPO 10.1 Tablet Battery Replacement, Remove Battery: paso 3, imagen 2 de 3 DOPO 10.1 Tablet Battery Replacement, Remove Battery: paso 3, imagen 3 de 3
    • Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose.
  4. DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: paso 4, imagen 1 de 3 DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: paso 4, imagen 2 de 3 DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: paso 4, imagen 3 de 3
    • Use a soldering iron to carefully remove wires from motherboard. Then remove battery.
Conclusión
Una persona más ha completado esta guía.
Kaitlyn Hayes
Miembro Desde 01/21/15
414 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 5-2, Brown Winter 2015 Miembro de USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 2,130
