Saltar al contenido principal
DJI Spark Cooling Fan Replacement
Qué necesitas
  1. DJI Spark Cooling Fan Replacement, Propellers: paso 1, imagen 1 de 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Cooling Fan Replacement: paso 2, imagen 1 de 2 DJI Spark Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Cooling Fan Replacement, Battery: paso 3, imagen 1 de 3 DJI Spark Cooling Fan Replacement, Battery: paso 3, imagen 2 de 3 DJI Spark Cooling Fan Replacement, Battery: paso 3, imagen 3 de 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Cooling Fan Replacement, Lid: paso 4, imagen 1 de 3 DJI Spark Cooling Fan Replacement, Lid: paso 4, imagen 2 de 3 DJI Spark Cooling Fan Replacement, Lid: paso 4, imagen 3 de 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Cooling Fan Replacement: paso 5, imagen 1 de 3 DJI Spark Cooling Fan Replacement: paso 5, imagen 2 de 3 DJI Spark Cooling Fan Replacement: paso 5, imagen 3 de 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Cooling Fan Replacement, Cooling Fan: paso 6, imagen 1 de 3 DJI Spark Cooling Fan Replacement, Cooling Fan: paso 6, imagen 2 de 3 DJI Spark Cooling Fan Replacement, Cooling Fan: paso 6, imagen 3 de 3
    • Remove the fan.
    • It is attached to the motherboard with several pieces of adhesive.
  7. DJI Spark Cooling Fan Replacement: paso 7, imagen 1 de 2 DJI Spark Cooling Fan Replacement: paso 7, imagen 2 de 2
    • Trace the fan wires to the side of the panel.
    • Unplug the wire from its connector.
Conclusión
Una persona más ha completado esta guía.
Uzochi Anyanwu
Miembro Desde 10/21/19
408 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,340
