Saltar al contenido principal
DJI Spark Controller Mobile Device Grip Replacement
Qué necesitas
  1. DJI Spark Controller Mobile Device Grip Replacement, Mobile Device Grip: paso 1, imagen 1 de 1
    • Unfold the arm.
    • Extend the controller’s arm as you would before normally flying the drone.
    • To avoid obstruction, make sure the screwheads of the grip are parallel to the body of the controller.
  2. DJI Spark Controller Mobile Device Grip Replacement: paso 2, imagen 1 de 3 DJI Spark Controller Mobile Device Grip Replacement: paso 2, imagen 2 de 3 DJI Spark Controller Mobile Device Grip Replacement: paso 2, imagen 3 de 3
    • Remove the grip.
    • Remove two screws using a T6 torx screwdriver.
    • Use this same procedure for both arms.
  3. DJI Spark Controller Mobile Device Grip Replacement: paso 3, imagen 1 de 2 DJI Spark Controller Mobile Device Grip Replacement: paso 3, imagen 2 de 2
    • Once both screws are removed, the grip parts come off easily.
    • Be carful when doing this step because the two parts of the grip might fall once the two screws are removed.
Conclusión
Amelia Hagberg
Miembro Desde 10/21/19
415 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 602
