Saltar al contenido principal
DJI Spark Camera Replacement
Qué necesitas
  1. DJI Spark Camera Replacement, Propellers: paso 1, imagen 1 de 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Camera Replacement: paso 2, imagen 1 de 2 DJI Spark Camera Replacement: paso 2, imagen 2 de 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Camera Replacement, Battery: paso 3, imagen 1 de 3 DJI Spark Camera Replacement, Battery: paso 3, imagen 2 de 3 DJI Spark Camera Replacement, Battery: paso 3, imagen 3 de 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Camera Replacement, Lid: paso 4, imagen 1 de 3 DJI Spark Camera Replacement, Lid: paso 4, imagen 2 de 3 DJI Spark Camera Replacement, Lid: paso 4, imagen 3 de 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Camera Replacement: paso 5, imagen 1 de 3 DJI Spark Camera Replacement: paso 5, imagen 2 de 3 DJI Spark Camera Replacement: paso 5, imagen 3 de 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Camera Replacement, Camera: paso 6, imagen 1 de 2 DJI Spark Camera Replacement, Camera: paso 6, imagen 2 de 2
    • Disconnect two gold antenna next to the internal GPS while removing the motherboard.
  7. DJI Spark Camera Replacement: paso 7, imagen 1 de 3 DJI Spark Camera Replacement: paso 7, imagen 2 de 3 DJI Spark Camera Replacement: paso 7, imagen 3 de 3
    • Remove all the Phillips #0 screws attaching the motherboard to the drone.
    • It is the piece with both the fan and GPS module on it.
  8. DJI Spark Camera Replacement: paso 8, imagen 1 de 2 DJI Spark Camera Replacement: paso 8, imagen 2 de 2
    • Remove the 3.0 mm Phillips #000 screw.
  9. DJI Spark Camera Replacement: paso 9, imagen 1 de 3 DJI Spark Camera Replacement: paso 9, imagen 2 de 3 DJI Spark Camera Replacement: paso 9, imagen 3 de 3
    • Remove the two Phillips #0 screws on the right and left sides.
    • Once removed, pull the front facing sensor out.
  10. DJI Spark Camera Replacement: paso 10, imagen 1 de 3 DJI Spark Camera Replacement: paso 10, imagen 2 de 3 DJI Spark Camera Replacement: paso 10, imagen 3 de 3
    • Gently remove the gimbal along with the camera from the top of the device.
Conclusión
Una persona más ha completado esta guía.
Amelia Hagberg
Miembro Desde 10/21/19
415 Reputación
3 Guías creadas
Equipo
2 comentarios
Good start, but missing many steps and details.
Basil Yokarinis - Contestar
I am now going to try and fix my drone. thank you so much
sebasnavarro1116 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 74
Todo El Tiempo: 5,840
