Saltar al contenido principal
DJI Phantom 4 Advanced Remote Controller Power Button Replacement
Qué necesitas
  1. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 2, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 2, imagen 2 de 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 3, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 3, imagen 2 de 2
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 4, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 4, imagen 2 de 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 5, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 5, imagen 2 de 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: paso 6, imagen 1 de 3 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: paso 6, imagen 2 de 3 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: paso 6, imagen 3 de 3
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 7, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 7, imagen 2 de 2
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 8, imagen 1 de 1
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
  9. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: paso 9, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: paso 9, imagen 2 de 2
    • Carefully remove the plastic. This will help you gain access to the power button panel.
  10. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 10, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 10, imagen 2 de 2
    • With a Phillips #00 screwdriver, remove the two screws on the power button panel.
  11. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: paso 11, imagen 1 de 1
    • Gently pull the power button out from the panel. Replace it with a new one.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 837
