Introducción
This guide will demonstrate step by step detailed instructions on how to safely remove and replace the Control Sticks of a DJI Phantom 4 Advanced Remote Controller. Since this operation will require to disconnect the motherboard is highly recommended to start this task with the appropriate tools on hand as well as enough time.
During this process s lot of connectors are required to be unplugged with caution to avoid damages to other parts , compromising the functionality of the remote controller.
Someone might need to replace the control sticks because of faultiness such as, inaccurate navigation, drifting directions without input, and control stick not functioning at all.
Qué necesitas
Remove the four screws with a Torx T8 screwdriver to access the back con board.
Disconnect ribbon tabs 1,2,5,8G, and 3.
Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
Then remove the plugs
