Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
  1. Remove the four screws with a Torx T8 screwdriver to access the back con board.
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. Remove three screws using a Phillips #00 screwdriver.
    • Remove three screws using a Phillips #00 screwdriver.
  3. With tweezers, gently remove the large con board tab. Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  5. Peel off the rubber grips to access the screw holes. Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  6. Pull apart the back plastic panel. Recommended tool for this would be the metal spudger, but not required.
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  7. Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands. Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
    • Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
  8. Remove back buttons and replace with new ones.
    • Remove back buttons and replace with new ones.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 222
