Saltar al contenido principal
DJI Phantom 3 Standard Remote Controller Battery Replacement
Qué necesitas
  1. DJI Phantom 3 Standard Remote Controller Battery Replacement, Battery: paso 1, imagen 1 de 2 DJI Phantom 3 Standard Remote Controller Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a Phillips #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Battery Replacement: paso 2, imagen 1 de 2 DJI Phantom 3 Standard Remote Controller Battery Replacement: paso 2, imagen 2 de 2
    • Remove the two 8 mm screws securing the battery to the controller using a JIS #00 screwdriver.
  3. DJI Phantom 3 Standard Remote Controller Battery Replacement: paso 3, imagen 1 de 3 DJI Phantom 3 Standard Remote Controller Battery Replacement: paso 3, imagen 2 de 3 DJI Phantom 3 Standard Remote Controller Battery Replacement: paso 3, imagen 3 de 3
    • Use the nylon-tipped tweezers to detach the three-prong battery attachment that connects the battery to the motherboard.
    • Remove the battery.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 41
Todo El Tiempo: 527
