Saltar al contenido principal
DJI Phantom 3 Advanced Motor Replacement
Qué necesitas
  1. DJI Phantom 3 Advanced Motor Replacement, Battery: paso 1, imagen 1 de 2 DJI Phantom 3 Advanced Motor Replacement, Battery: paso 1, imagen 2 de 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Motor Replacement: paso 2, imagen 1 de 2 DJI Phantom 3 Advanced Motor Replacement: paso 2, imagen 2 de 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Motor Replacement, Cover: paso 3, imagen 1 de 1
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced Motor Replacement: paso 4, imagen 1 de 1
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced Motor Replacement: paso 5, imagen 1 de 2 DJI Phantom 3 Advanced Motor Replacement: paso 5, imagen 2 de 2
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced Motor Replacement: paso 6, imagen 1 de 2 DJI Phantom 3 Advanced Motor Replacement: paso 6, imagen 2 de 2
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced Motor Replacement: paso 7, imagen 1 de 3 DJI Phantom 3 Advanced Motor Replacement: paso 7, imagen 2 de 3 DJI Phantom 3 Advanced Motor Replacement: paso 7, imagen 3 de 3
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced Motor Replacement: paso 8, imagen 1 de 3 DJI Phantom 3 Advanced Motor Replacement: paso 8, imagen 2 de 3 DJI Phantom 3 Advanced Motor Replacement: paso 8, imagen 3 de 3
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
  9. DJI Phantom 3 Advanced Motor Replacement, Motor: paso 9, imagen 1 de 3 DJI Phantom 3 Advanced Motor Replacement, Motor: paso 9, imagen 2 de 3 DJI Phantom 3 Advanced Motor Replacement, Motor: paso 9, imagen 3 de 3
    • Turn the drone upside down with the motors facing the table.
    • Unscrew the four 5.5mm long 3mm screws directly under the motor using a 2.0mm hex bit screwdriver.
  10. DJI Phantom 3 Advanced Motor Replacement: paso 10, imagen 1 de 2 DJI Phantom 3 Advanced Motor Replacement: paso 10, imagen 2 de 2
    • Remove the glue that covers the three wires that connect the motor to the flight controller. Use a plastic opening tool or a metal tool if needed.
    • Repeat for each arm.
  11. DJI Phantom 3 Advanced Motor Replacement: paso 11, imagen 1 de 2 DJI Phantom 3 Advanced Motor Replacement: paso 11, imagen 2 de 2
    • Trace the black, yellow, and red wires from the motor to the flight controlle .
    • Desolder the three wires where they connect to the flight controller. Check out this desoldering guide to learn how to desolder: Desoldering Guide.
    • Take out the motor and repeat for the other motors if needed.
Conclusión
8 personas más completaron esta guía.
Tate Morell
Miembro Desde 10/06/16
782 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-2, Livingston Fall 2016 Miembro de Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
3 Miembros
12 Guías creadas
Un comentario
Great teardown, clear instructions, thank you!
Kyle Michael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 35
Todo El Tiempo: 8,380
