Saltar al contenido principal
DJI Mavic Pro Upper Shell Replacement
Qué necesitas
  1. DJI Mavic Pro Upper Shell Replacement, Battery: paso 1, imagen 1 de 3 DJI Mavic Pro Upper Shell Replacement, Battery: paso 1, imagen 2 de 3 DJI Mavic Pro Upper Shell Replacement, Battery: paso 1, imagen 3 de 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Upper Shell Replacement, Upper Shell: paso 2, imagen 1 de 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Upper Shell Replacement: paso 3, imagen 1 de 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Upper Shell Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Upper Shell Replacement: paso 5, imagen 1 de 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Upper Shell Replacement: paso 6, imagen 1 de 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Upper Shell Replacement: paso 7, imagen 1 de 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team S17-G3, White Fall 2018 Miembro de Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Miembros
14 Guías creadas
2 comentarios
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - Contestar
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 55
Todo El Tiempo: 5,323
