Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
DJI Mavic Pro GPS Module Replacement
Qué necesitas
    1. DJI Mavic Pro GPS Module Replacement, Battery: paso 1, imagen 1 de 3 DJI Mavic Pro GPS Module Replacement, Battery: paso 1, imagen 2 de 3 DJI Mavic Pro GPS Module Replacement, Battery: paso 1, imagen 3 de 3
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      Pregunta a FixBot
      Agregar Comentario
    1. DJI Mavic Pro GPS Module Replacement, Upper Shell: paso 2, imagen 1 de 1
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      Pregunta a FixBot
      Agregar Comentario
    2. DJI Mavic Pro GPS Module Replacement: paso 3, imagen 1 de 1
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      Pregunta a FixBot
      Agregar Comentario
    3. DJI Mavic Pro GPS Module Replacement: paso 4, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      Pregunta a FixBot
      Agregar Comentario
    4. DJI Mavic Pro GPS Module Replacement: paso 5, imagen 1 de 1
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      Pregunta a FixBot
      Agregar Comentario
    5. DJI Mavic Pro GPS Module Replacement: paso 6, imagen 1 de 1
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      Pregunta a FixBot
      Agregar Comentario
    6. DJI Mavic Pro GPS Module Replacement: paso 7, imagen 1 de 1
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      Pregunta a FixBot
      Agregar Comentario
    1. DJI Mavic Pro GPS Module Replacement, GPS Module: paso 8, imagen 1 de 1
      • Flip the upper shell over so the metallic plate is facing up.
      • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
      • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    2. DJI Mavic Pro GPS Module Replacement: paso 9, imagen 1 de 1
      • Pry the metallic plate up from the upper shell by using a nylon spudger.
      • Remove the metallic plate from the upper shell by lifting the plate up and out.
      • You may hear a popping sound when prying the metallic plate, but no damage will occur.
      Pregunta a FixBot
      Agregar Comentario
    3. DJI Mavic Pro GPS Module Replacement: paso 10, imagen 1 de 1
      • Use tweezers to remove the GPS Module from the upper shell.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
8 personas más completaron esta guía.
Kyle Kelser
Miembro Desde 10/08/18
644 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G3, White Fall 2018 Miembro de Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
Miembros de 4
67 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 44
Ultimos 30 días: 111
Todo El Tiempo: 10,632
