Saltar al contenido principal
DJI Mavic Pro GPS Module Replacement
Qué necesitas
  1. DJI Mavic Pro GPS Module Replacement, Battery: paso 1, imagen 1 de 3 DJI Mavic Pro GPS Module Replacement, Battery: paso 1, imagen 2 de 3 DJI Mavic Pro GPS Module Replacement, Battery: paso 1, imagen 3 de 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro GPS Module Replacement, Upper Shell: paso 2, imagen 1 de 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro GPS Module Replacement: paso 3, imagen 1 de 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro GPS Module Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro GPS Module Replacement: paso 5, imagen 1 de 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro GPS Module Replacement: paso 6, imagen 1 de 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro GPS Module Replacement: paso 7, imagen 1 de 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro GPS Module Replacement, GPS Module: paso 8, imagen 1 de 1
    • Flip the upper shell over so the metallic plate is facing up.
    • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
    • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
  9. DJI Mavic Pro GPS Module Replacement: paso 9, imagen 1 de 1
    • Pry the metallic plate up from the upper shell by using a nylon spudger.
    • Remove the metallic plate from the upper shell by lifting the plate up and out.
    • You may hear a popping sound when prying the metallic plate, but no damage will occur.
  10. DJI Mavic Pro GPS Module Replacement: paso 10, imagen 1 de 1
    Comprar
    • Use tweezers to remove the GPS Module from the upper shell.
Conclusión
8 personas más completaron esta guía.
Kyle Kelser
Miembro Desde 10/08/18
598 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G3, White Fall 2018 Miembro de Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 80
Todo El Tiempo: 8,904
