Introducción
I did a dumb and bonked my not-under-warranty drone into a tree branch. If you’re here you probably bonked yours into something too. Hopefully this will help you get your baby airborne again!
Qué necesitas
Desolder the larger gray motor wire running to the arm to be replaced
Desolder the larger white motor wire
Desolder the larger black motor wire
Desolder the smaller black LED wire
Desolder the smaller white LED wire
Remove 6 hex screws
Remove 2 hex screws with longer posts
If replacing the right front leg, unplug the white front antenna cable
If replacing the left front leg, unplug the black front antenna cable
On the top of the drone, gently release the rear leg cable bundle from its cable management clip
Lift the white or black wire from the previous step up through the drone
6 personas más completaron esta guía.
4 comentarios
Bravo, thanks for the guide! I found myself in the middle of my repair cursing that antenna wire as I didn’t want to pull up the main board. Then I remembered my trusty secret weapon “ifixit.com”. Oh did you save the day for sure, I was hoping for another access point to unclip the antenna, just had no idea where that would be. I’ve been a fixer for 20 + years, but DJI drones are not something you generally just want to go poking and prodding around blind. So a big thanks for helping me get in and out with ninja precision fellow fixer!
Glad I could help! They’re definitely complicated little buggers.
Did you use some glue along the three wires for the motor arm? This was destroyed when I replaced one damaged arm. Do you know what type of glue would be good to use?
I didn’t use any glue, and I haven’t had any issues with it leaving it out. It looks like the original glue is some sort of silicone glue. I would think you could probably use an electronics-safe silicone adhesive, like something you could get from a hobby shop, but I haven’t tried it myself so I couldn’t say for sure.
