Introducción
You will not be able to access the lens without following these steps. Removing the lens does not take a lot of force since it is on a hinge and should lift out easily. However, none of the items you come in contact with leading up to the lens removal are sturdy so don't be afraid to use some force.
Partes
No se especificaron partes.
Casi Terminas!
Conclusión
2 comentarios
I need to know the same
