Saltar al contenido principal
DBPOWER RD-810 Power Supply Circuit Replacement
Qué necesitas
  1. DBPOWER RD-810 Power Supply Circuit Replacement, Top Cover: paso 1, imagen 1 de 2 DBPOWER RD-810 Power Supply Circuit Replacement, Top Cover: paso 1, imagen 2 de 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Power Supply Circuit Replacement: paso 2, imagen 1 de 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Power Supply Circuit Replacement, Motherboard and LED Bulb: paso 3, imagen 1 de 3 DBPOWER RD-810 Power Supply Circuit Replacement, Motherboard and LED Bulb: paso 3, imagen 2 de 3 DBPOWER RD-810 Power Supply Circuit Replacement, Motherboard and LED Bulb: paso 3, imagen 3 de 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Power Supply Circuit Replacement: paso 4, imagen 1 de 3 DBPOWER RD-810 Power Supply Circuit Replacement: paso 4, imagen 2 de 3 DBPOWER RD-810 Power Supply Circuit Replacement: paso 4, imagen 3 de 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Power Supply Circuit Replacement: paso 5, imagen 1 de 3 DBPOWER RD-810 Power Supply Circuit Replacement: paso 5, imagen 2 de 3 DBPOWER RD-810 Power Supply Circuit Replacement: paso 5, imagen 3 de 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Power Supply Circuit Replacement, Power Supply Circuit: paso 6, imagen 1 de 3 DBPOWER RD-810 Power Supply Circuit Replacement, Power Supply Circuit: paso 6, imagen 2 de 3 DBPOWER RD-810 Power Supply Circuit Replacement, Power Supply Circuit: paso 6, imagen 3 de 3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Power Supply Circuit Replacement: paso 7, imagen 1 de 2 DBPOWER RD-810 Power Supply Circuit Replacement: paso 7, imagen 2 de 2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
Conclusión
Una persona más ha completado esta guía.
John Russell
Miembro Desde 02/14/18
914 Reputación
9 Guías creadas
Equipo
USF Tampa, Team S5-G3, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 392
