Saltar al contenido principal
D-Link HD Wi-Fi Camera Microphone Replacement
Qué necesitas
  1. D-Link HD Wi-Fi Camera Microphone Replacement, Motherboard: paso 1, imagen 1 de 1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Microphone Replacement: paso 2, imagen 1 de 2 D-Link HD Wi-Fi Camera Microphone Replacement: paso 2, imagen 2 de 2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera Microphone Replacement: paso 3, imagen 1 de 2 D-Link HD Wi-Fi Camera Microphone Replacement: paso 3, imagen 2 de 2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Microphone Replacement, Microphone: paso 4, imagen 1 de 1
    • To remove the front cover, place index finger in the center and pull away from the frame. This may take a little effort, but should not require an opening tool.
  5. D-Link HD Wi-Fi Camera Microphone Replacement: paso 5, imagen 1 de 2 D-Link HD Wi-Fi Camera Microphone Replacement: paso 5, imagen 2 de 2
    • After the cover is removed, unscrew the two Phillips #00 5.0mm screws. Then the board should slide right out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 32
Todo El Tiempo: 464
