Introducción
The motherboard is the internal component of your router that performs all basic functions. It is the most important part of your device. If your D-Link EBR-2310 router is non-operational, your motherboard most likely needs to be replaced. Follow this guide for instructions on how to do so.
Qué necesitas
Begin by placing the wired router face down.
Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
Use a plastic opening tool between the edges of the router and gently pry the device apart.
Release the clips as you work your way around the device to avoid breaking them.
Separate the front and back case of the router.
Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
You have now removed the logic board from your device.
Una persona más ha completado esta guía.
