Saltar al contenido principal
D-Link EBR-2310 LED Light Replacement
Qué necesitas
  1. D-Link EBR-2310 LED Light Replacement, Remove Plastic Screw Coverings: paso 1, imagen 1 de 1
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 LED Light Replacement, Remove Screws: paso 2, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 LED Light Replacement, Pry Open The Router: paso 3, imagen 1 de 1
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: paso 4, imagen 1 de 2 D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: paso 4, imagen 2 de 2
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: paso 5, imagen 1 de 2 D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: paso 5, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 LED Light Replacement, Remove Bottom Case: paso 6, imagen 1 de 1
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
  7. D-Link EBR-2310 LED Light Replacement, Locate Problematic LED light: paso 7, imagen 1 de 1
    • Locate the problematic LED light on the motherboard.
    • Using a plastic opening tool, very gently tilt its black base backwards.
  8. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: paso 8, imagen 1 de 2 D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: paso 8, imagen 2 de 2
    • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
  9. D-Link EBR-2310 LED Light Replacement, Remove the LED Light: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
  10. D-Link EBR-2310 LED Light Replacement, Complete Removal: paso 10, imagen 1 de 1
    • You should now have a removed LED light, ready to be replaced with a new one.
Conclusión
Jessica
Miembro Desde 09/19/14
428 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 390
