Saltar al contenido principal
D-Link DCS-825L Back Casing Replacement
Qué necesitas
  1. D-Link DCS-825L Back Casing Replacement, Accent Ring: paso 1, imagen 1 de 1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L Back Casing Replacement: paso 2, imagen 1 de 1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L Back Casing Replacement: paso 3, imagen 1 de 1
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L Back Casing Replacement, Back Casing: paso 4, imagen 1 de 2 D-Link DCS-825L Back Casing Replacement, Back Casing: paso 4, imagen 2 de 2
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L Back Casing Replacement: paso 5, imagen 1 de 3 D-Link DCS-825L Back Casing Replacement: paso 5, imagen 2 de 3 D-Link DCS-825L Back Casing Replacement: paso 5, imagen 3 de 3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L Back Casing Replacement: paso 6, imagen 1 de 2 D-Link DCS-825L Back Casing Replacement: paso 6, imagen 2 de 2
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L Back Casing Replacement: paso 7, imagen 1 de 3 D-Link DCS-825L Back Casing Replacement: paso 7, imagen 2 de 3 D-Link DCS-825L Back Casing Replacement: paso 7, imagen 3 de 3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
Conclusión
April Ulrich
Miembro Desde 10/09/18
205 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G5, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 384
