Saltar al contenido principal
D-Link DCS-825L Antenna Replacement
Qué necesitas
  1. D-Link DCS-825L Antenna Replacement, Accent Ring: paso 1, imagen 1 de 1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L Antenna Replacement: paso 2, imagen 1 de 1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L Antenna Replacement: paso 3, imagen 1 de 1
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L Antenna Replacement, Back Casing: paso 4, imagen 1 de 2 D-Link DCS-825L Antenna Replacement, Back Casing: paso 4, imagen 2 de 2
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L Antenna Replacement: paso 5, imagen 1 de 3 D-Link DCS-825L Antenna Replacement: paso 5, imagen 2 de 3 D-Link DCS-825L Antenna Replacement: paso 5, imagen 3 de 3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L Antenna Replacement: paso 6, imagen 1 de 2 D-Link DCS-825L Antenna Replacement: paso 6, imagen 2 de 2
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L Antenna Replacement: paso 7, imagen 1 de 3 D-Link DCS-825L Antenna Replacement: paso 7, imagen 2 de 3 D-Link DCS-825L Antenna Replacement: paso 7, imagen 3 de 3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
  8. D-Link DCS-825L Antenna Replacement, Antenna: paso 8, imagen 1 de 1
    • Once you have the back casing removed from the other half of the device, it should look like this with the antenna poking out.
  9. D-Link DCS-825L Antenna Replacement: paso 9, imagen 1 de 3 D-Link DCS-825L Antenna Replacement: paso 9, imagen 2 de 3 D-Link DCS-825L Antenna Replacement: paso 9, imagen 3 de 3
    • There will be a light yellow rubber stopper that is holding the antenna in place.
    • With your tweezers, gently tug on the stopper to make it come out, or at least come loose.
    • If the stopper does not completely come out, use the round top of the antenna to push down on it.
    • You can do this simply by pulling the antenna as close to the back casing as possible, and then pushing down on it until the rubber stopper comes out completely.
    • After it has come out, it can either be taken off from the antenna and set aside, or it can be kept on.
  10. D-Link DCS-825L Antenna Replacement: paso 10, imagen 1 de 2 D-Link DCS-825L Antenna Replacement: paso 10, imagen 2 de 2
    • Once the rubber stopper has been pushed out, you will now be able to easily pull the antenna out from the back casing.
    • After it has been removed, you are now able to replace the antenna of your Wi-Fi Baby Camera.
Conclusión
Alexis Clopton
Miembro Desde 10/09/18
97 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S1-G5, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 451
