Saltar al contenido principal
D-Link DCS-5222L Speaker Replacement
Qué necesitas
  1. D-Link DCS-5222L Speaker Replacement, Speaker: paso 1, imagen 1 de 3 D-Link DCS-5222L Speaker Replacement, Speaker: paso 1, imagen 2 de 3 D-Link DCS-5222L Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Remove the four rubber pieces to gain access to the screws.
    • Remove the four 7mm screws with a #1 Phillips screwdriver.
    • Remove the bottom of the camera body.
  2. D-Link DCS-5222L Speaker Replacement: paso 2, imagen 1 de 2 D-Link DCS-5222L Speaker Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using safety tweezers, disconnect the 2-wire connector with the red and black leads located close to the ethernet and SD ports.
    • Disconnect the cables gently.
  3. D-Link DCS-5222L Speaker Replacement: paso 3, imagen 1 de 2 D-Link DCS-5222L Speaker Replacement: paso 3, imagen 2 de 2
    • The speaker is circular, black and silver in color with a red and black cord. It is easily removed from the upper body of the camera with your fingers or safety tweezers.
Conclusión
Jason Munyon
Miembro Desde 10/30/18
268 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team S2-G5, Peak Fall 2018 Miembro de UMass Dartmouth, Team S2-G5, Peak Fall 2018
UMASSD-PEAK-F18S2G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 305
