Introducción
If your camera is failing to move in a certain direction one of the two motors inside may be malfunctioning. If this is the case the motor will need to be replaced. The replacement process is pretty simple and doesn't need many tools. It is important to keep track of the small screws, they are easily lost.
  1. Remove the four rubber feet on the bottom of the camera with tweezers. Remove the four screws using a Phillips #1 screwdriver. Remove the lower piece of the camera body.
    • Remove the four rubber feet on the bottom of the camera with tweezers.
    • Remove the four screws using a Phillips #1 screwdriver.
    • Remove the lower piece of the camera body.
  2. Remove the motherboard and bottom of the camera body. Disconnect the five cables from the motherboard using tweezers.
    • Remove the motherboard and bottom of the camera body.
    • Disconnect the five cables from the motherboard using tweezers.
  3. Use a #1 Phillips screwdriver to remove the two 7mm screws holding the motor in place. Use a #1 Phillips screwdriver to remove the two 7mm screws holding the motor in place.
    • Use a #1 Phillips screwdriver to remove the two 7mm screws holding the motor in place.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Using your hands, separate the bottom of the body from the upper portion. Using your hands, separate the bottom of the body from the upper portion.
    • Using your hands, separate the bottom of the body from the upper portion.
  6. To remove the top of the camera you must push in the black tabs using the spudger. There are 3 tabs per side. While pushing in the tabs, you can now lift the top black portion of the camera using your hands.
    • To remove the top of the camera you must push in the black tabs using the spudger. There are 3 tabs per side.
    • While pushing in the tabs, you can now lift the top black portion of the camera using your hands.
  7. With a little wiggle, the camera module will come free from the body. Unscrew the two 7mm screws on the camera using a #1 Phillips screwdriver.
    • With a little wiggle, the camera module will come free from the body.
    • Unscrew the two 7mm screws on the camera using a #1 Phillips screwdriver.
  8. Pry apart the camera housing with your fingers to reveal the second motor. Pry apart the camera housing with your fingers to reveal the second motor.
    • Pry apart the camera housing with your fingers to reveal the second motor.
  9. Unscrew the two 6mm screws holding the motor in place with a #1 Phillips screwdriver.
    • Unscrew the two 6mm screws holding the motor in place with a #1 Phillips screwdriver.
Conclusión
Una persona más ha completado esta guía.
Jason Munyon
Miembro Desde 30/10/18
268 Reputación
2 Guías creadas
Equipo
Where can I buy new motor?
Michael Williams - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 9
Todo El Tiempo: 85
