Saltar al contenido principal
D-Link DCS-5222L Motherboard Replacement
Qué necesitas
  1. D-Link DCS-5222L Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 D-Link DCS-5222L Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove the four rubber feet on the bottom of the camera using your fingers or a pair of tweezers.
  2. D-Link DCS-5222L Motherboard Replacement: paso 2, imagen 1 de 1
    • Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
  3. D-Link DCS-5222L Motherboard Replacement: paso 3, imagen 1 de 2 D-Link DCS-5222L Motherboard Replacement: paso 3, imagen 2 de 2
    • Using your hands, open the camera body by wiggling the bottom free from the upper shell.
    • Open the shell carefully, as the motherboard is attached to the bottom of the body; all of the components in the upper body are accordingly connected to the bottom. Likewise, the WiFi antenna is mounted to the upper shell, but a wire connects it to the motherboard on the bottom of the body.
  4. D-Link DCS-5222L Motherboard Replacement: paso 4, imagen 1 de 3 D-Link DCS-5222L Motherboard Replacement: paso 4, imagen 2 de 3 D-Link DCS-5222L Motherboard Replacement: paso 4, imagen 3 de 3
    • Disconnect the five quick connections attaching the various cables to the motherboard with your fingers or blunt ended tweezers.
  5. D-Link DCS-5222L Motherboard Replacement: paso 5, imagen 1 de 2 D-Link DCS-5222L Motherboard Replacement: paso 5, imagen 2 de 2
    • Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
    • Soldering Irons are hot and can burn you and ignite flammable materials.
  6. D-Link DCS-5222L Motherboard Replacement: paso 6, imagen 1 de 1
    • Using a #1 Phillips screwdriver, remove the single 7mm screw holding the motherboard in place.
  7. D-Link DCS-5222L Motherboard Replacement: paso 7, imagen 1 de 3 D-Link DCS-5222L Motherboard Replacement: paso 7, imagen 2 de 3 D-Link DCS-5222L Motherboard Replacement: paso 7, imagen 3 de 3
    • Wiggle free the motherboard from the bottom of the body.
    • There are two pegs that limit the motherboard's rotation. Have some patience when wiggling it free.
    • The power and ethernet ports have ledges along their top surface. These must be removed from the body at an angle relative to the horizontal.
Conclusión
Ryan Null
Miembro Desde 10/26/18
377 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team S2-G5, Peak Fall 2018 Miembro de UMass Dartmouth, Team S2-G5, Peak Fall 2018
UMASSD-PEAK-F18S2G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,039
