Saltar al contenido principal
D-Link DCS-5222L Lens Replacement
Qué necesitas
  1. D-Link DCS-5222L Lens Replacement, Lens: paso 1, imagen 1 de 3 D-Link DCS-5222L Lens Replacement, Lens: paso 1, imagen 2 de 3 D-Link DCS-5222L Lens Replacement, Lens: paso 1, imagen 3 de 3
    • Remove the four rubber feet with tweezers to access the screws.
    • Remove all four 7mm screws by using a #1 Phillips screwdriver.
    • Then, with your hands, pull off the lower part of the camera body.
  2. D-Link DCS-5222L Lens Replacement: paso 2, imagen 1 de 3 D-Link DCS-5222L Lens Replacement: paso 2, imagen 2 de 3 D-Link DCS-5222L Lens Replacement: paso 2, imagen 3 de 3
    • On the base motherboard, there are five connecting cables. Disconnect all of them from the motherboard gently using safety tweezers.
    • Do not cut or damage the cables.
    • Disconnecting the antenna cable from motherboard is not necessary.
  3. D-Link DCS-5222L Lens Replacement: paso 3, imagen 1 de 3 D-Link DCS-5222L Lens Replacement: paso 3, imagen 2 de 3 D-Link DCS-5222L Lens Replacement: paso 3, imagen 3 de 3
    • Remove the two 7mm screws holding the motor using a #1 Phillips screwdriver.
    • Pull off the motor and lift away the midbody of the camera using your hands.
  4. D-Link DCS-5222L Lens Replacement: paso 4, imagen 1 de 2 D-Link DCS-5222L Lens Replacement: paso 4, imagen 2 de 2
    • Separate the black camera shroud from the upper body by prying loose the tabs with a plastic opening tool or spudger.
    • Use your hands to wiggle the shroud free.
  5. D-Link DCS-5222L Lens Replacement: paso 5, imagen 1 de 3 D-Link DCS-5222L Lens Replacement: paso 5, imagen 2 de 3 D-Link DCS-5222L Lens Replacement: paso 5, imagen 3 de 3
    • Use a #1 Phillips screwdriver to unscrew the four 5mm screws on both sides of the black camera housing to separate it from white body.
    • Unscrew the two 7mm #1 Phillips screws on both sides of the camera housing to open it.
  6. D-Link DCS-5222L Lens Replacement: paso 6, imagen 1 de 3 D-Link DCS-5222L Lens Replacement: paso 6, imagen 2 de 3 D-Link DCS-5222L Lens Replacement: paso 6, imagen 3 de 3
    • Gently disconnect the three cables from the small motherboard using safety tweezers.
    • Use a #0 Phillips screwdriver to remove the two black 2mm screws and a #1 Phillips screwdriver to remove the 2 silver 6mm screws.
    • Separate the board from the black housing.
  7. D-Link DCS-5222L Lens Replacement: paso 7, imagen 1 de 3 D-Link DCS-5222L Lens Replacement: paso 7, imagen 2 de 3 D-Link DCS-5222L Lens Replacement: paso 7, imagen 3 de 3
    • Using your fingers, remove the focus adjustment ring.
    • Twist the lens to unscrew it from the camera module.
    • Replace the broken lens with new one and reassemble all parts of the camera respectively.
Conclusión
Una persona más ha completado esta guía.
Atefeh Rahmani
Miembro Desde 10/27/18
172 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team S2-G5, Peak Fall 2018 Miembro de UMass Dartmouth, Team S2-G5, Peak Fall 2018
UMASSD-PEAK-F18S2G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 930
