Saltar al contenido principal
D-Link DCS-2630L Wi-Fi Camera Microphone Replacement
Qué necesitas
  1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Back casing: paso 1, imagen 1 de 1
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 3, imagen 1 de 1
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 4, imagen 1 de 1
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Microphone: paso 5, imagen 1 de 1
    • Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
  6. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 6, imagen 1 de 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 6, imagen 2 de 2
    • Detach the white plug by gently pulling on the black wires.
  7. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 7, imagen 1 de 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 7, imagen 2 de 2
    • Remove the circuit board to expose the camera body.
    • At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
  8. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 8, imagen 1 de 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 8, imagen 2 de 2
    • Gently pull on the grey wire to detach the microphone from the camera body.
  9. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 9, imagen 1 de 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 9, imagen 2 de 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: paso 9, imagen 3 de 3
    • Detach the microphone from the circuit board by gently pulling on the grey wire.
Conclusión
Equipo
IUPUI, Team S4-G2, Baechle Spring 2018 Miembro de IUPUI, Team S4-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 368
