Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Computer Hardware, utiliza nuestros manuales de servicio .
  1. Desmontaje del HUB USB 2.0 de 7 puertos D-Link, Caja: paso 1, imagen 1 de 2 Desmontaje del HUB USB 2.0 de 7 puertos D-Link, Caja: paso 1, imagen 2 de 2
    • HUB USB 2.0 de 7 puertos de D-Link Nº de modelo: DUB-H7 H/W Ver.: C1 Código UPC: 790069252389 Caja
  2. Desmontaje del HUB USB 2.0 de 7 puertos D-Link, Contenido de la caja: paso 2, imagen 1 de 2 Desmontaje del HUB USB 2.0 de 7 puertos D-Link, Contenido de la caja: paso 2, imagen 2 de 2
    • Cargador
    • cable USB
    • Para abrir el HUB USB solo hay 4 tornillos debajo de las dos almohadillas.
Un agradecimiento especial a estos traductores:
en es
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Juan
Miembro Desde 11/03/14
138 Reputación
2 Guías creadas
5 comentarios
Anyone can tell what is the output voltage on this ? Mine shows 4.88V and I don't know if I should return it or not. My USB devices seem unstable.
adrianTNT - Contestar
I returned this low performance hub. But the USB spec says that voltage should be 5.00±0.25 V. So, voltage may not be the issue. If the device works correctly when directly connected to the computer, then just return the USB HUB, and upload a video (on youtube or somewhere else) so people can see the problem and not buy this low performance USB HUB.
If you need a high performance USB HUB just get this:
http://plugable.com/products/usb2-hub-ag...
Juan -
These hubs have been better than the previous version, but only in that the two right hand ports are capable of fast charging. Almost all devices benefit from 2.1 amp fast charging now. As for reliability, they suck just as much as every other stupid USB sharing device.
Kelly - Contestar
Thanks for this! But I'm confused: is this single TT or multi TT?
samulialapuranen - Contestar
Can anyone tell me what a good DVD burner I can buy to burn copy write disk
tony brookshire - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 58
Todo El Tiempo: 6,464
