Saltar al contenido principal
D-Link HD Wi-Fi Camera Motherboard Replacement
Qué necesitas
  1. D-Link   HD Wi-Fi Camera Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link   HD Wi-Fi Camera Motherboard Replacement: paso 2, imagen 1 de 2 D-Link   HD Wi-Fi Camera Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link   HD Wi-Fi Camera Motherboard Replacement: paso 3, imagen 1 de 2 D-Link   HD Wi-Fi Camera Motherboard Replacement: paso 3, imagen 2 de 2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
Conclusión
Un comentario
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
Azlin Rahim - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 868
