Saltar al contenido principal
CygoLite Night Rover Rubber Charging Input Gasket Replacement
Qué necesitas
  1. CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: paso 1, imagen 1 de 3 CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: paso 1, imagen 2 de 3 CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: paso 1, imagen 3 de 3
    • Place the CygoLite on a flat surface with the bottom side facing up.
    • Locate the four screws on the bottom of the device.
    • Unscrew them with a Phillips head screwdriver and remove the bottom casing.
  2. CygoLite Night Rover Rubber Charging Input Gasket Replacement: paso 2, imagen 1 de 2 CygoLite Night Rover Rubber Charging Input Gasket Replacement: paso 2, imagen 2 de 2
    • Locate the rubber gasket on the side of the device.
    • Place your new replacement rubber gasket onto the side of the casing and gently place the top of the case back on top of it.
    • Be sure to line up the grooves in the casing with the grooves on the rubber gasket.
Conclusión
Trent Vigar
Miembro Desde 10/22/12
101 Reputación
1 Guía escrita
Equipo
Clemson, Team 14-3, Benson Fall 2012 Miembro de Clemson, Team 14-3, Benson Fall 2012
CLEM-BENSON-F12S14G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 353
