Introducción
The light bulbs on the device are prone to breakage and burn out. This guide provides information on how to replace the light bulbs.
Partes
No se requieren partes.
  1. Place the device with the bottom facing upwards. Using a Phillips head screwdriver remove the screws on the bottom of the device.
    • Place the device with the bottom facing upwards.
    • Using a Phillips head screwdriver remove the screws on the bottom of the device.
  2. Flip the device so that the top is facing upwards. Lift the top casing to expose the light. Lift the top casing to expose the light.
    • Flip the device so that the top is facing upwards.
    • Lift the top casing to expose the light.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    Todos somos Genios
  4. Remove light out of the socket. Remove light out of the socket. Remove light out of the socket.
    • Remove light out of the socket.
  5. Obtain a replacement bulb and plug it into the empty socket. Obtain a replacement bulb and plug it into the empty socket. Obtain a replacement bulb and plug it into the empty socket.
Conclusión
Una persona más ha completado esta guía.
Kelly
Miembro Desde 22/10/12
131 Reputación
1 Guía escrita
Equipo
Clemson, Team 14-3, Benson Fall 2012 Miembro de Clemson, Team 14-3, Benson Fall 2012
CLEM-BENSON-F12S14G3
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 3
Todo El Tiempo: 591
