Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cyclone Range Hood (Model CY3000R) Circuit Board Replacement
Qué necesitas
    1. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement, Circuit Board: paso 1, imagen 1 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement, Circuit Board: paso 1, imagen 2 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement, Circuit Board: paso 1, imagen 3 de 3
      • To avoid unforeseen electric shocks, turn off the fuse supplying power to your range hood to avoid the risk of electrocution.
      • Empty all of the grease from the grease container and clean it.
      Pregunta a FixBot
      Agregar Comentario
    2. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 2, imagen 1 de 2 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 2, imagen 2 de 2
      • The panel will be loose after the screws and bulbs are removed; be sure to support the panel while removing the screws and bulbs.
      • Remove the five 10 mm Phillips #1 screws securing the panel while holding the panel in place.
      Pregunta a FixBot
      Agregar Comentario
    3. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 3, imagen 1 de 2 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 3, imagen 2 de 2
      • Turn the LED bulbs counterclockwise and remove them.
      • Push the panel down to remove it from the body.
      Pregunta a FixBot
      Agregar Comentario
    4. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 4, imagen 1 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 4, imagen 2 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 4, imagen 3 de 3
      • Carefully remove the four 5 mm Phillips #1 screws from the board box.
      • Open the lid.
      Pregunta a FixBot
      Agregar Comentario
    5. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 5, imagen 1 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 5, imagen 2 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 5, imagen 3 de 3
      • Pull out the ten-pin white head cable located on the left side of the board.
      • Remove the cables one by one on the right side of the board.
      • Install the replacement board into the board box.
      Pregunta a FixBot
      Agregar Comentario
    6. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 6, imagen 1 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 6, imagen 2 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 6, imagen 3 de 3
      • Insert the tips of the wires into the board's protective plastic that comes with your replacement board.
      • To reinsert the wires, insert the two black wires into the first two slots on the top.
      • The second row is for the white wires, which can be attached in any order; for the remaining red wires, adhere to the ordered numbers attached to the wires.
      Pregunta a FixBot
      Agregar Comentario
    7. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 7, imagen 1 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 7, imagen 2 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 7, imagen 3 de 3
      • Replace the lid.
      • Reinstall the four 5 mm Phillips #1 screws to secure the lid.
      • Shut the panel.
      Pregunta a FixBot
      Agregar Comentario
    8. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 8, imagen 1 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 8, imagen 2 de 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: paso 8, imagen 3 de 3
      • Set the panel in place, and secure all five 10 mm Phillips #1 screws to their respective locations while holding the panel.
      • Replace the LED bulbs.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Enjoy your fully functional range.
Hesam Esmaeilianaraghi
Miembro Desde 07/06/22
157 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 37
Todo El Tiempo: 940
