Introducción
The case of the keyboard is plastic and can break. This guide will show how to replace the case of the keyboard.
  1. Be sure to unplug the keyboard before starting the disassembly. Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the sixteen 5 mm length screws using the Phillips head #2. One of the screws may be located underneath a manufacturer's sticker.
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  4. Lift up and remove the plastic casing.
    • Lift up and remove the plastic casing.
Conclusión
Braydon Lantz
Miembro Desde 12/02/18
193 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S15-G2, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 113
