Saltar al contenido principal
CyberPowerPC Fangbook MS-1763 Key Replacement
Qué necesitas
  1. CyberPowerPC Fangbook MS-1763 Key Replacement, Key: paso 1, imagen 1 de 1
    • Lift up the corner of your desired key using a spudging tool to create leverage.
  2. CyberPowerPC Fangbook MS-1763 Key Replacement: paso 2, imagen 1 de 1
    • Apply lifting force to the corner until a portion of the inner key clips are detached.
  3. CyberPowerPC Fangbook MS-1763 Key Replacement: paso 3, imagen 1 de 1
    • Repeat the previous step on all the keys corners and remove the key from its socket.
  4. CyberPowerPC Fangbook MS-1763 Key Replacement: paso 4, imagen 1 de 1
    • Place your new key in the appropriate slot positioned as if the key was fully functioning.
  5. CyberPowerPC Fangbook MS-1763 Key Replacement: paso 5, imagen 1 de 1
    • Apply force to the key until all key clips are properly attached.
Conclusión
Terrias
Miembro Desde 02/08/18
177 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 524
