Saltar al contenido principal
CyberPowerPC Fangbook MS-1763 Battery Replacement
Qué necesitas
  1. CyberPowerPC Fangbook MS-1763 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Save all of your work and turn off the laptop before beginning.
    • Close the laptop and flip it so that the bottom side is facing up.
    • Locate the battery compartment.
  2. CyberPowerPC Fangbook MS-1763 Battery Replacement: paso 2, imagen 1 de 1
    • Pull the latches away from the battery compartment. The lid of the compartment should pop out of place.
  3. CyberPowerPC Fangbook MS-1763 Battery Replacement: paso 3, imagen 1 de 1
    • Tilt the lid so that it leans away from the laptop and exposes the battery below.
    • Remove the battery from the newly opened compartment.
Conclusión
Insert a new battery and close the compartment lid to complete.
Una persona más ha completado esta guía.
Un comentario
what is the battery name?
Jimmy Grant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 1,056
