Saltar al contenido principal
Cyber-Shot DSC-H55 Battery Replacement
  1. Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: paso 1, imagen 1 de 2 Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: paso 1, imagen 2 de 2
    • Before you begin it is important to know where the battery compartment is. The battery compartment is located on the bottom of the camera.
    • Place the camera upside down with the lens facing you so that the battery compartment is facing up.
    • Place your thumb on the lid of the battery compartment making sure you put some pressure.
  2. Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: paso 2, imagen 1 de 3 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: paso 2, imagen 2 de 3 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: paso 2, imagen 3 de 3
    • Grab the camera with one hand, with your thumb still on the lid, apply pressure and slide to the right.
    • Lift the lid, exposing the battery and SD slot.
  3. Cyber-Shot DSC-H55 Battery Replacement, Removing Battery: paso 3, imagen 1 de 1
    • There is a small blue tab on the right of the compartment. In order to remove the battery, move this tab aside and the battery will pop up.
  4. Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: paso 4, imagen 1 de 2 Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: paso 4, imagen 2 de 2
    • Grab the new battery. Place the battery so that the arrow is pointing down and facing you. Next, slide the the battery into the battery compartment.
    • The blue tab will lock the battery into place.
Conclusión
Una persona más ha completado esta guía.
Jazmin Young
Miembro Desde 01/21/15
608 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 6-2, Brown Winter 2015 Miembro de USF Tampa, Team 6-2, Brown Winter 2015
USFT-BROWN-W15S6G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 963
