Introducción
This disassembly guide will illustrate how to completely disassemble the Cuisinart WMR-CA(CR). This can be a messy process if the device is used. Do not disassemble while plugged in. All screws can be removed with a #2 Phillips head screwdriver.
Qué necesitas
Take off the plastic plate to expose the central wire hub on the bottom of the waffle maker.
Remove the central 10 mm gray screw as shown to detach the hub and stainless steel frame from the bottom side heating element.
Additionally, remove the two 10 mm black screws holding down the AC power supply cord.
Una persona más ha completado esta guía.
