Saltar al contenido principal
Cuisinart TOA-60FR Power Cord Replacement
Qué necesitas
  1. Cuisinart TOA-60FR Power Cord Replacement, Outside removal: paso 1, imagen 1 de 1
    • Using a 25-hexagon head, unscrew these 7.31 mm three screws.
  2. Cuisinart TOA-60FR Power Cord Replacement: paso 2, imagen 1 de 2 Cuisinart TOA-60FR Power Cord Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
    • Pull off the back.
  3. Cuisinart TOA-60FR Power Cord Replacement: paso 3, imagen 1 de 3 Cuisinart TOA-60FR Power Cord Replacement: paso 3, imagen 2 de 3 Cuisinart TOA-60FR Power Cord Replacement: paso 3, imagen 3 de 3
    • Flip the oven upside down.
    • Pick the grey stoppers out with a sprudger.
    • Using a Phillips #1 screwdriver, remove these three 11 mm screws.
  4. Cuisinart TOA-60FR Power Cord Replacement: paso 4, imagen 1 de 2 Cuisinart TOA-60FR Power Cord Replacement: paso 4, imagen 2 de 2
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
  5. Cuisinart TOA-60FR Power Cord Replacement: paso 5, imagen 1 de 3 Cuisinart TOA-60FR Power Cord Replacement: paso 5, imagen 2 de 3 Cuisinart TOA-60FR Power Cord Replacement: paso 5, imagen 3 de 3
    • Pull the top piece off.
    • Push down before pulling up to release the tabs.
  6. Cuisinart TOA-60FR Power Cord Replacement, Power Cord: paso 6, imagen 1 de 1
    • Take the needle nose pliers and cut off the crimped-on-wire connectors.
    • Pressed down hard. These wires are thick.
    • These are crimped on wire conncetors so they can not be twisted off. The only way to remove them is by cutting off the wire.
  7. Cuisinart TOA-60FR Power Cord Replacement: paso 7, imagen 1 de 3 Cuisinart TOA-60FR Power Cord Replacement: paso 7, imagen 2 de 3 Cuisinart TOA-60FR Power Cord Replacement: paso 7, imagen 3 de 3
    • Strip the wires back with wire strippers. Or carefully take the needle nose pliers and cut gently to only make a mark on the jacket and not the wires. Then pull with the pliers to remove the jacket.
  8. Cuisinart TOA-60FR Power Cord Replacement: paso 8, imagen 1 de 3 Cuisinart TOA-60FR Power Cord Replacement: paso 8, imagen 2 de 3 Cuisinart TOA-60FR Power Cord Replacement: paso 8, imagen 3 de 3
    • Take the white, blue, and black wire together and push togther
    • Then take the pliers and twist them until they are all combined.
  9. Cuisinart TOA-60FR Power Cord Replacement: paso 9, imagen 1 de 2 Cuisinart TOA-60FR Power Cord Replacement: paso 9, imagen 2 de 2
    • Crimp the wire connector with a crimper or pliers
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 10
Ultimos 30 días: 21
Todo El Tiempo: 142
