Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Cooking surfaces may be heating unevenly because the the plates and heating coils are out of alignment. This guide will take you through the steps to disassemble the device, allowing you to reassemble it correctly.
Partes
No se especificaron partes.
  1. Ensure device is turned unplugged, cooled down and clean before attempting any replacements. Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  4. Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  5. Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  6. Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out. Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
Conclusión
Una persona más ha completado esta guía.
Kayla Londono
Miembro Desde 15/04/16
584 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-12, Maness Spring 2016 Miembro de Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 50
Todo El Tiempo: 2,210
