Saltar al contenido principal
Cuisinart Griddler GR- 4N Knobs Replacement
Qué necesitas
  1. Cuisinart Griddler GR- 4N Knobs Replacement, Cooking Surfaces: paso 1, imagen 1 de 2 Cuisinart Griddler GR- 4N Knobs Replacement, Cooking Surfaces: paso 1, imagen 2 de 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N Knobs Replacement: paso 2, imagen 1 de 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N Knobs Replacement: paso 3, imagen 1 de 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N Knobs Replacement: paso 4, imagen 1 de 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N Knobs Replacement: paso 5, imagen 1 de 2 Cuisinart Griddler GR- 4N Knobs Replacement: paso 5, imagen 2 de 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N Knobs Replacement, Cuisinart Griddler GR- 4N Disassembly: paso 6, imagen 1 de 1
    • Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
    • Move the circuit board to the side so it is out of the way.
  7. Cuisinart Griddler GR- 4N Knobs Replacement: paso 7, imagen 1 de 1
    • Remove the two 6 mm Phillips #2 screws that secure the white plastic LED holder.
  8. Cuisinart Griddler GR- 4N Knobs Replacement, Knobs: paso 8, imagen 1 de 1
    • Pinch back plastic arms on knob while pulling out the knob.
  9. Cuisinart Griddler GR- 4N Knobs Replacement: paso 9, imagen 1 de 1
    • Pop the new knob back into the hole and the repair is complete.
Conclusión
2 personas más completaron esta guía.
Kayla Londono
Miembro Desde 04/15/16
632 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-12, Maness Spring 2016 Miembro de Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Miembros
6 Guías creadas
14 comentarios
Where do you find the replacement knobs?
Chris Reece - Contestar
Wish I knew! I need two knobs. Are their universal knobs out there that can be substituted?
sfk -
im in same boat can't find the dials/knobs- 2 of mine are broken and useless
Mark Stevens - Contestar
Cuisinart offers NO help. I will have to toss out a $100.00 unit over a $2.00 part.
Nick - Contestar
I have several cuisinart appliances. I won't ever buy another. I need one replacement knob, the best they can do is 20 percent off on a new griddler . I can get that from bed bath and beyond. Thanks cuisinart, finding new brands. Cuisinart is dead to me.
allen brathwaite - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 70
Todo El Tiempo: 10,067
