Saltar al contenido principal
Cuisinart Griddler GR- 4N Button Spring Replacement
Qué necesitas
  1. Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: paso 1, imagen 1 de 2 Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: paso 1, imagen 2 de 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N Button Spring Replacement: paso 2, imagen 1 de 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N Button Spring Replacement: paso 3, imagen 1 de 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N Button Spring Replacement: paso 4, imagen 1 de 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N Button Spring Replacement: paso 5, imagen 1 de 2 Cuisinart Griddler GR- 4N Button Spring Replacement: paso 5, imagen 2 de 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N Button Spring Replacement, Button Spring: paso 6, imagen 1 de 1
    • Depress one of the gray tabs on the side of the housing.
  7. Cuisinart Griddler GR- 4N Button Spring Replacement: paso 7, imagen 1 de 1
    • Pull out the black button and the spring will also come out within it.
  8. Cuisinart Griddler GR- 4N Button Spring Replacement: paso 8, imagen 1 de 1
    • Pull out the spring, and insert the replacement spring making sure it is correctly aligned.
Conclusión
2 personas más completaron esta guía.
Laine Aro
Miembro Desde 04/11/16
167 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 1-12, Maness Spring 2016 Miembro de Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 39
Todo El Tiempo: 3,684
