Introducción
This guide teaches the user how to replace the power switch assembly in your Cuisinart DLC-8F. The removal of the power switch assembly first requires the removal of the bottom hood and all of this can be done with just a Phillips #2 screwdriver. This is an easy process and should only take about 10 minutes.
Qué necesitas
Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
2 personas más completaron esta guía.
