Saltar al contenido principal
Cuisinart DLC-8F Automatic Circuit Breaker Replacement
Qué necesitas
  1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: paso 1, imagen 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: paso 1, imagen 2 de 2
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 2, imagen 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 2, imagen 2 de 2
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 3, imagen 1 de 1
    • Remove the two 62 mm Phillips #2 screws from the cable retaining clip.
  4. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 4, imagen 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 4, imagen 2 de 2
    • Lift off the cable retaining
  5. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 5, imagen 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 5, imagen 2 de 2
    • Pull apart the two wires of the power cable at their connections as shown.
  6. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 6, imagen 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 6, imagen 2 de 2
    • Lift out the cable.
  7. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: paso 7, imagen 1 de 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: paso 7, imagen 2 de 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: paso 7, imagen 3 de 3
    • Pull out the power cable screw stand with your hand.
  8. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 8, imagen 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 8, imagen 2 de 2
    • Remove the two 15 mm Phillips #2 screws on the automatic circuit breaker.
  9. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 9, imagen 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 9, imagen 2 de 2
    • Pull out the automatic circuit breaker with your hand.
  10. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 10, imagen 1 de 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 10, imagen 2 de 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: paso 10, imagen 3 de 3
    • Pull off the three wires by grabbing from the base of the wire.
Conclusión
Una persona más ha completado esta guía.
David Colman
Miembro Desde 01/25/17
573 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-6, Banghart Winter 2017 Miembro de Cal Poly, Team 8-6, Banghart Winter 2017
CPSU-BANGHART-W17S8G6
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 571
