Saltar al contenido principal
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement
Qué necesitas
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement, Power Cord: paso 1, imagen 1 de 1
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: paso 2, imagen 1 de 1
    • Remove the black plastic covering from the motor base.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: paso 3, imagen 1 de 1
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: paso 4, imagen 1 de 1
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: paso 5, imagen 1 de 1
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: paso 6, imagen 1 de 1
    • Fit the wires back into the motor base and place the new power cord in the slot.
Conclusión
By the end of this guide< you will have successfully replaced the power cord to your device.
Una persona más ha completado esta guía.
Reagan Burns
Miembro Desde 04/02/15
119 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-1, Lancaster Spring 2015 Miembro de Cal Poly, Team 24-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G1
2 Miembros
1 Guía escrita
4 comentarios
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - Contestar
I need one also. drshtender1@gmail.com
Feivel Garnick -
Where can you buy the replacement cord?
ruby48lp - Contestar
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
Riley Carns - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 1,634
