Introducción
A broken switch means electricity is not flowing through your device. Removing and replacing this component requires soldering. Check out this soldering guide for instructions.
Qué necesitas
Turn the food processor's base upside down by lifting it up and turning it over.
Position the base so that the on and pulse buttons are facing you.
Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
Desolder the white, black and red connections from the switch by using a soldering iron.
Una persona más ha completado esta guía.
