Introducción
This guide will show you how to remove the buttons on your food processor and replace them if they are damaged. This guide only requires the use of a screwdriver and nut driver, but gives you a look at the inside of your food processor.
Herramientas
Partes
No se especificaron partes.
Turn the food processor's base upside down by lifting it up and turning it over.
Position the base so that the on and pulse buttons are facing you.
Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
Una persona más ha completado esta guía.
