Saltar al contenido principal
Cuisinart DFP-14BCN Buttons Replacement
Qué necesitas
  1. Cuisinart DFP-14BCN Buttons Replacement, Bowl: paso 1, imagen 1 de 3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: paso 1, imagen 2 de 3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: paso 1, imagen 3 de 3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Buttons Replacement: paso 3, imagen 1 de 3 Cuisinart DFP-14BCN Buttons Replacement: paso 3, imagen 2 de 3 Cuisinart DFP-14BCN Buttons Replacement: paso 3, imagen 3 de 3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Buttons Replacement: paso 4, imagen 1 de 1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Buttons Replacement: paso 5, imagen 1 de 3 Cuisinart DFP-14BCN Buttons Replacement: paso 5, imagen 2 de 3 Cuisinart DFP-14BCN Buttons Replacement: paso 5, imagen 3 de 3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Buttons Replacement, Back Casing: paso 6, imagen 1 de 2 Cuisinart DFP-14BCN Buttons Replacement, Back Casing: paso 6, imagen 2 de 2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Buttons Replacement: paso 7, imagen 1 de 2 Cuisinart DFP-14BCN Buttons Replacement: paso 7, imagen 2 de 2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Buttons Replacement: paso 8, imagen 1 de 3 Cuisinart DFP-14BCN Buttons Replacement: paso 8, imagen 2 de 3 Cuisinart DFP-14BCN Buttons Replacement: paso 8, imagen 3 de 3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Buttons Replacement: paso 9, imagen 1 de 2 Cuisinart DFP-14BCN Buttons Replacement: paso 9, imagen 2 de 2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Buttons Replacement, Buttons: paso 10, imagen 1 de 3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: paso 10, imagen 2 de 3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: paso 10, imagen 3 de 3
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Buttons Replacement: paso 11, imagen 1 de 2 Cuisinart DFP-14BCN Buttons Replacement: paso 11, imagen 2 de 2
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Buttons Replacement: paso 12, imagen 1 de 1
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Buttons Replacement: paso 13, imagen 1 de 3 Cuisinart DFP-14BCN Buttons Replacement: paso 13, imagen 2 de 3 Cuisinart DFP-14BCN Buttons Replacement: paso 13, imagen 3 de 3
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
Conclusión
Una persona más ha completado esta guía.
Sonya Dick
Miembro Desde 10/05/16
352 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-3, Livingston Fall 2016 Miembro de Cal Poly, Team 10-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G3
3 Miembros
7 Guías creadas
Un comentario
Is there a source for replacing the button assembly?
BadMahoney - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 1,094
