Saltar al contenido principal
Cuisinart DCC-3200 Hot Plate Replacement
Qué necesitas
  1. Cuisinart DCC-3200 Hot Plate Replacement, Hot Plate: paso 1, imagen 1 de 1
    • Unplug the device and flip it over so the bottom is facing upwards.
    • Remove the four screws.
    • Remove the bottom panel.
  2. Cuisinart DCC-3200 Hot Plate Replacement: paso 2, imagen 1 de 1
    • Remove the two screws from the silver brace.
  3. Cuisinart DCC-3200 Hot Plate Replacement: paso 3, imagen 1 de 2 Cuisinart DCC-3200 Hot Plate Replacement: paso 3, imagen 2 de 2
    • Use a spudger to wedge the red tube off of the metal.
    • Repeat this for the other side of the silver pipe deeper in the device.
  4. Cuisinart DCC-3200 Hot Plate Replacement: paso 4, imagen 1 de 1
    • Pick up the middle pipe and slide the hot plate out of its area.
    • Apply new thermal paste to the hot plate.
Conclusión
2 personas más completaron esta guía.
Hamad Khan
Miembro Desde 03/04/16
385 Reputación
3 Guías creadas
Equipo
5 comentarios
Where can one purchase the burner plate?
john Vet - Contestar
Same question as John Vet
Bob Stimson - Contestar
Did anyone ever get a response as to where a replacement could be purchased?
Joe Lubrant -
Did response provide required info?
Joe Lubrant - Contestar
Same question: where can we purchase the burner plate?
Cresny - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 70
Todo El Tiempo: 4,981
