Saltar al contenido principal
Cuisinart DCC-1200 Coffee Carafe Handle Replacement
Qué necesitas
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: paso 1, imagen 1 de 3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: paso 1, imagen 2 de 3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: paso 1, imagen 3 de 3
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: paso 2, imagen 1 de 2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: paso 2, imagen 2 de 2
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: paso 3, imagen 1 de 1
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: paso 4, imagen 1 de 2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: paso 4, imagen 2 de 2
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: paso 5, imagen 1 de 1
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
Conclusión
3 personas más completaron esta guía.
Austin Wheaton
Miembro Desde 02/15/18
861 Reputación
4 Guías creadas
Equipo
UW Stout, Team S8-G1, Ogden Spring 2018 Miembro de UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Miembros
5 Guías creadas
Un comentario
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
Max - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 35
Todo El Tiempo: 3,729
