Saltar al contenido principal
Cuisinart DCC-1100 Drip Spring Replacement
  1. Cuisinart DCC-1100 Drip Spring Replacement, Drip Spring: paso 1, imagen 1 de 1
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Drip Spring Replacement: paso 2, imagen 1 de 1
    • Remove the coffee pot and open the top lid.
  3. Cuisinart DCC-1100 Drip Spring Replacement: paso 3, imagen 1 de 2 Cuisinart DCC-1100 Drip Spring Replacement: paso 3, imagen 2 de 2
    • Remove the basket filter holder.
  4. Cuisinart DCC-1100 Drip Spring Replacement: paso 4, imagen 1 de 1
    • Remove the basket filter from the holder.
  5. Cuisinart DCC-1100 Drip Spring Replacement: paso 5, imagen 1 de 1
    • Press up on the drip spring mechanism.
  6. Cuisinart DCC-1100 Drip Spring Replacement: paso 6, imagen 1 de 2 Cuisinart DCC-1100 Drip Spring Replacement: paso 6, imagen 2 de 2
    • While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
  7. Cuisinart DCC-1100 Drip Spring Replacement: paso 7, imagen 1 de 1
    • Remove the spring from the dripper.
Conclusión
8 personas más completaron esta guía.
Josh Harvey
Miembro Desde 01/25/18
886 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S20-G4, Passmore Spring 2018 Miembro de USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Miembros
7 Guías creadas
4 comentarios
Where do you find replacement springs?
Mrich - Contestar
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
Chris Rockett -
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
Raymond Classen - Contestar
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
ncrenshaw4 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 46
Todo El Tiempo: 11,528
